1990 Porsche 944S2
Old 01-13-2013, 01:46 AM
LSXRX7's Avatar
LSXRX7 is on a distinguished road
1990 Porsche 944S2
Year: 1990
Make: Porsche
Model: 944
Price: $14250
Mileage: 156240
Color: Zyclamen Pearl
Location (State): CA
Transmission: Manual
Drivetrain: Rear Wheel Drive
1990 Porsche 944S2 - Zyclamen pearl, black leather interior, optional power sport seats, 156k miles, 91 octane only used. Maintained by: RSR Autosport, clean title, clean Carfax, 993 Cup II (17"x9" +55) F/R, Porsche crest center caps, Hankook Ventus RS3 255/40ZR-17, Koni sport dampers, Paragon/Hyperco coilover kit 10"x2.5" 200lb springs. Lowered rear suspension, Stop Tech braided brake lines, Motul RBF660 brake fluid. Thousands invested in maintenance and repairs. Maintenance: timing belt, tensioner, water pump, front timing cover seal, distributor cap & rotor, NGK spark plugs, Bosch ignition coil, lower radiator hose, heater hoses, powder coated valve cover, valve cover gasket, seals and cam seals x3, K&N replacement air filter, Mahle fuel filter, fuel pressure regulator, Bosch fuel pump relay, power steering reservoir hoses, power steering pump rebuild, oil pan gasket, oil pan drain bolt & washer, oil cooler O-rings, Mobil 1 synthetic 10w/40 oil, Mahle oil filter, rear main seal, rod bearings, rod nuts, ABS pump, front sway bar bushings, clutch assembly, shift linkage & shifter, left rear half shaft, A/C dryer, 968 A/C compressor, A/C expansion valve (POA), A/C switch, freeze 12 Freon, positive battery cable & terminal, climate control ***** & face plate, instrument panel right trim, defroster switch, sun visor clips, shift boot assembly, Alpine CDE-122 CD player, Pioneer 4"x6" speakers, all new light bulbs, tow hook cover, 3M clear protector replacement kit, right power window motor, right power window switch. All work done within the last 10 months. Amazingly clean automobile, extremely reliable, desirable and timeless classic. NO CRACKS IN DASH!! Full service history with maintenance records. All books and owners manuals included. This car gets more thumbs up than my E90 M3. $14,250 obo. Call or text: Mark 619-813-8832. Email bmozaffarian1@san.rr.com
Old 01-14-2013, 10:05 PM
LSXRX7's Avatar
Autocheck report ran today and clean
Old 01-15-2013, 07:54 PM
SpeedFreak2000's Avatar
SpeedFreak2000 is on a distinguished road
Nice S2. Wasn't aware they made Maraschino Red past '88 tho, thought Velvet Red replaced it...repaint? Same color as my '88 951.
Old 01-17-2013, 09:39 AM
LSXRX7's Avatar
It is an origanal color and original paint. It is Zyclamen Pearl. Only a handful where made in this color.
Old 01-17-2013, 10:01 AM
Very interesting, do a quick google search on maraschino red, it literally looks identical. Wonder if Porsche renamed the color.
At any rate, great car and GLWS!
Old 01-17-2013, 12:30 PM
LSXRX7's Avatar
Thank you!
Old 01-30-2013, 09:24 PM
LSXRX7's Avatar
Bump
2lflat4
11-18-2019 05:05 PM
joseph_number1
07-19-2018 05:45 PM
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
08-21-2015 06:34 AM
08-20-2015 12:17 PM
Quick Reply: 1990 Porsche 944S2
