Difference between PSM & Traction Control
Old 12-19-2008, 11:06 PM
ssaa77's Avatar
ssaa77 is on a distinguished road
Sorry if this has been discussed before, but read this today:
Six airbags (including side curtain), antilock disc brakes and stability control are included on all 2007 Porsche 911 models except the GT3, which does without the stability control.
I noticed that the GT3 has "traction control"....but not "stability control"....what's the difference?
Old 12-19-2008, 11:10 PM
GT3 Chuck's Avatar
Administrator
the difference is that if you lack skill the GT3 will get away from you
Old 12-19-2008, 11:18 PM
Slow4s's Avatar
Slow4s has a spectacular aura aboutSlow4s has a spectacular aura about
Does anyone know if the 996 turbo has stability control?
Thanks,
Alex
ssaa77's Avatar
will get away from you if you turn traction control off? As opposed to in 997S, where if you turn PSM off, it still helps you?
Old 12-19-2008, 11:40 PM
GT3 Chuck's Avatar
Administrator
the 996 GT3 does not have PSM or traction control..I don't believe the 996 turbo has them either...
Old 12-20-2008, 12:22 AM
docjackson1's Avatar
docjackson1 will become famous soon enough
chuck-i had a 996tt-i am sure that it had traction, and i am pretty sure it had stability. i think that the 996 gt2 and gt3 didn't.
Old 12-20-2008, 12:47 AM
yrralis1's Avatar
I had two 996 cars (non Turbo) . At the time PSM (traction) was an option. In the early model it engaged a bit too easily (IMO) .
The 997 model also has the PSM mated with the variocam plus engine . PASM also includes suspension settings (only familiar with "S" model) . What the sport chrono offers is a "medium" (sport) setting as opposed to it either being on or off.
As for the 997.2 --I don't know yet.
Turbo has PTM (porsche traction management AWD) and PASM (suspension) .
Old 12-20-2008, 12:34 PM
ssaa77's Avatar
Sorry if I'm being dense/stupid here, but what's the difference between traction management and stability management. Isn't it the same thing?
Old 12-20-2008, 01:48 PM
NorthVan's Avatar
Stability Control uses brakes to control the car in a slide. It can control the brakes to one or more wheels.
Traction Controls the amount of power sent to the drive wheels from the engine.
I was at a track day in the rain, we closed the track down and used a long sweeping corner as a skid pad. I turned my PSM off and tried to throw the back end out. Once the back end went loose (turned wheel hard and hit the gas at the same time) my car went around in a 360. PSM works very well, try throughing your rear end out in the wet with both PSM on and off, you will be surprised how much it does to save your but!
Old 12-20-2008, 07:14 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
Let me add: stability control is often referred to a "yaw control" where yaw means "to deviate from the planned course". it works all 4 wheels to keep you on the road. traction control modulates power to the right and left rear wheels to minimize wheelspin. if you have 4 wd....errr hmmm. Well it still works because yaw control is watching the steering input and where the car is going to end up while tc is just looking for rear wheel spin hope that helps Gerry
Old 12-21-2008, 03:58 PM
Slow4s's Avatar
Thanks,
Alex
No one knows??........
Old 12-21-2008, 06:26 PM
NorthVan's Avatar
Go ask the 996TT boys, I don't have one and haven't even driven one. I have passed several on the track though!
Old 12-24-2008, 12:45 AM
cephas's Avatar
cephas is on a distinguished road
when one of these start working, will any light on the dash blink?
Old 12-24-2008, 11:02 AM
Gpjli's Avatar
PSM will throw a quick light but your hands are usually too full at the time to see it, if you get my "drift". In severe conditions the car will intervene aggressively as the brakes grab and the engine cuts down while it catches you (guess how I know). You will know something just happened. Even Porsche driving school (do it) didn't prepare me for the violence of the action on a dry street. I have not made the same mistake since (too much throttle on cold tires around a 90 deg. corner). Never had TC on a Porsche but if you break the rears loose from a start it flashes you to tell you what you already know.
alwaysbored786
04-19-2016 05:51 AM
DetomasoGTS74
11-11-2015 09:01 AM
Sales@RSW
09-03-2015 09:34 AM
jyupitt1
08-31-2015 12:58 PM
hacellular
08-31-2015 08:34 AM
Quick Reply: Difference between PSM & Traction Control
