295/45-20 tires. Does it work?? Input needed
Old 08-16-2009, 05:12 PM
boostedtwin's Avatar
boostedtwin is a glorious beacon of lightboostedtwin is a glorious beacon of lightboostedtwin is a glorious beacon of lightboostedtwin is a glorious beacon of lightboostedtwin is a glorious beacon of lightboostedtwin is a glorious beacon of light
Looking for different options of tire sizes. Decided to get a set of 20's but don't want to run 275/40-20. I'm torn between 275/45 0r 295/45. Does the 295 works with no rubbing? Just affraid of rubbing on turns and such due to the diameter.
295/45-20 30.5 diameter
275/45-20 29.8 diameter
275/40-20 28.6 diameter
295/35-21 29.1
285/35-22 29.9
Input needed.
Old 08-17-2009, 03:46 AM
ONE234's Avatar
ONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud of
the possible issue with rubbing aside.
you realise that by changing to 295 (20cm wider) and going up a profile (45, as opposed to 40) the overall rolling aspect is hugely altered
your speedo will be off by up to 10mph (ticket time )
just rough gusses.
ok, just checked, speedo will be out 4.38 mph.
275x40 dia is 728mm
295x45 dia is 773.5
circumfrence is 2287.08 mm
295 tyres is 2430.02mm
difference is 142.38mm (thats a lot....)
your choice.
Old 08-17-2009, 05:17 AM
You got a point there. Something to consider.
COBB Tuning
11-09-2015 08:02 PM
mikespeed95
09-14-2015 09:48 AM
vr6tee
08-29-2015 03:52 AM
oddjob142
08-24-2015 05:49 PM
Fadi
08-21-2015 03:43 AM
Quick Reply: 295/45-20 tires. Does it work?? Input needed
