How do you remove a 996 shift knob?
Old 01-13-2010, 05:52 PM
nijoma's Avatar
nijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud ofnijoma has much to be proud of
How do you remove a 996 shift ****?
I just got a 997 shifter to install, I lifted the trim around the shift boot and the rest looks easy. However, the **** and boot, are they 1 piece? Do I just pull the shift **** off? Is there a set screw?It is a 996 2000 Cabrio. I have to pull pretty hard if is is pull off. Any tips would be great. Thanks
Old 01-13-2010, 07:39 PM
996mk1aero's Avatar
996mk1aero is on a distinguished road
it is easier if you get behind the front seats and pull from there. just sit in the back and pull up and it should pop off
Old 01-13-2010, 10:08 PM
ls911's Avatar
ls911 has a spectacular aura aboutls911 has a spectacular aura aboutls911 has a spectacular aura about
Snap the trim ring, pull the boot over the **** and there is a screw that that needs removed. At that point the **** and boot come off as one no problem.
That was on my 2001, hope it helps you out
Old 01-14-2010, 07:49 AM
nijoma's Avatar
Thanks for the help
I got it off today, it is a pull off just pull hard. So for those with a 2000 996 Cab. no set screw. Thanks
Old 01-15-2010, 03:55 PM
rodgerdodger's Avatar
rodgerdodger is on a distinguished road
Now that you got it fixed
How do you like the 997 shifter compared to the 996 shifter. Did you go with the stock 997 or the short 997 shifter?
Old 01-15-2010, 04:41 PM
nijoma's Avatar
It is the stock 997 shifter
I have not put it in yet because I am looking into upgrading the shift linkage, just not sure to go with agency power or vertex auto. If anyone has an opinion let me know.
Old 01-16-2010, 07:47 AM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
I have the agency power linkage, but I don't think there is a big difference between this and the Vertex one. The biggest difference is just replacing the stock piece, which is plastic and tends to wear and get loose, addiing play to the feel of the shifter.
pshep138
09-01-2015 09:45 AM
LiquidElephant
08-27-2015 06:17 PM
ECS Tuning - VW
08-26-2015 12:13 PM
ECS Tuning - VW
08-19-2015 08:58 AM
Quick Reply: How do you remove a 996 shift knob?
