A/C Stinks with a Musty Smell?
Howdy
I have a 997 2006 with 35k.
Bought it a few thousand miles ago.
Love it but it has a musty smell when I turn on the AC.
Is there a way I can clean out the AC Filter and make this baby smell better ? Is there such a thing? I am very naive to this.
You can also buy a HVAC odor remover
http://www.5starshine.com/info-clean...r-remover.html
You should get a cabin air sanitizing service performed...while Cabin Air Filter replacement helps to reduce dust, pollen, and particulates in the air, it does not address the mold and mildew that produce unpleasant, musty odors.
Cabin air sanitizing service helps eliminate these odors by cleaning and freshening the ducts, coils, and vents inside the vehicle climate control system. Together these two services help improve the quality of the vehicle’s in-cabin air quality, for fresher, cleaner, sanitized air.
This service utilizes a fine mist – significantly smaller than aerosol droplets – allowing them to remain airborne longer and travel further. Using the vehicle’s own climate control system, micro-droplets are drawn into the intake vents, penetrating and treating the entire system, including the evaporator, heater core and air-ducts.
Well known within the automotive OEM and Tier-1 supplier community, HVAC-odor impacts both foreign and domestic alike.
Root-cause centers on odor caused by fungus, bacteria and other microbes growing inside the evaporator core, a moisture-laden environment conducive to organism-growth. While endemic to AC-systems, vehicle weight, cost and efficiency drivers have resulted in ever-more compact (e.g. increased fin-density) heat exchangers more prone to moisture-trap.
To address the issue post-sale, OEM’s offer mechanical solutions like Ford’s Purge Module (PN# F8ZX-19980-AA) or GM’s Electronic Evaporator Dryer (EED) while their newer systems increasingly incorporate a coating process to retard organism-growth.
The aftermarket offers a range of options including in-system mechanical solutions similar to those offered by the OEM’s, aerosol spray-solutions, liquid coating-solutions and evaporative “mist” solutions.
Try this from Einszett:
http://www.1z-usa.com/AC_Cleaner.html
I have not used this product, but have their waxes and detail spray and those work great. You can call them and they give you really good advice on care care.
One comment regarding do-it-yourself foam deodorizers. Be very careful during application. Since the foam is expanding, it can easily get into places where you don't want. I used Einszett on both my 944 Turbo and about a year later w/ my Cadillac CTS. The 944 worked great, however during the application on the CTS, the foam backed up in the center stack and burned out my climate control system. Replacement of the board was $500. Fortunately, my dealer covered it under warranty, suggesting that it was just a coincidence (wink, wink).
My recommendation would be to have the dealer perform any air conditioning cleansing. I can't imagine it being much more than 1 hours labor and if they break anything, it's on their dime.
