40K Service
Old 09-19-2012, 08:41 PM
jabed92694's Avatar
jabed92694 will become famous soon enough
40K Service
Anyone get a 40k service done recently? What did the dealer do and what was the cost? Is it considered a major or minor? I'm about to do my 40k, anything additional I should have them check??
Thanks!
Old 09-19-2012, 09:17 PM
Poshaman's Avatar
Poshaman has a spectacular aura aboutPoshaman has a spectacular aura about
I had a 40K service done a few months ago at a dealership. It was considered at a major service which included spark plugs and brake fluid flush. I paid $1600 for the service and it was painful.
Old 09-19-2012, 11:02 PM
bellwilliam's Avatar
bellwilliam is on a distinguished road
pls correct me if I am wrong.
I don't think Porsche specify plug change at 40k miles.
I believe it is just an oil change, air filter (15 min max) and cabin filter (5 min max).
Old 09-19-2012, 11:33 PM
VM997C4S's Avatar
VM997C4S is on a distinguished road
I was quoted little over $800. It was five year 30000k miles
Old 09-20-2012, 06:28 AM
wwilliams88's Avatar
wwilliams88 is a glorious beacon of lightwwilliams88 is a glorious beacon of lightwwilliams88 is a glorious beacon of lightwwilliams88 is a glorious beacon of lightwwilliams88 is a glorious beacon of lightwwilliams88 is a glorious beacon of light
It's considered major and, yes, they recommend changing the spark plugs at 36K miles for the 08 997.1 and 40K miles for the 997.2. For the 05-07 997.1, spark plugs at 60K miles. Here is the list for the 997.2. I changed the air and cabin filters myself as well as the wiper blades. Came to ~$1200 and included a new belt (which i requested replacement, not required until 60K miles), new spark plugs, change oil, brake fluid, and all of the 40K inspections underlined below. Takes most of the day to complete.
Maintenance Checklist
Boxster/Cayman (987) & 911 Carrera/S (997) (2009)
Required Maintenance and Lubrication Service
(USA & Canadian Vehicles Only, Not For 911 Turbo/GT2 (997), use separate checklists)
* Oil Change
Every 10,000 miles (15,000 km) or 1 year. See Below Check Box.
Maintenance (Labor Operation 03 16 00 ..) See Technical Manual
After 40,000, 80,000, 120,000, 180,000 miles (60,000, 120,000, 180,000, 240,000 km) etc.
Note: If the mileage for scheduled maintenance is not reached, maintenance must be performed no later than after
4, 8, 12..... years.
The terms ‘check’ and ‘inspection’ include all necessary subsequent work such as adjusting, readjusting, correcting and
topping off, but do not include repairing, replacing and reconditioning parts or assemblies.
Diagnosis system: Read fault memory; reset maintenance interval/Read and record range information on R.O.
Change engine oil and oil filter (Every 10,000 miles/15,000 km, see separate Oil Change Sheet, PNA 000 162 EF)
Vehicle underside and engine compartment: Visual inspection for leaks (oils and fluids) and abrasion (lines and hoses);
Underbody panels: visual inspection for completeness, installation and damage
Coolant hoses: Check condition
Radiators and air intakes: Visual inspection for external debris and blockage
Coolant: Check level and antifreeze protection level
Air filter: Replace filter element
Pollen filter: Replace filter element
Fuel lines and connections: Visual inspection for damage and leaks
Brake system: Visual inspection of the brake pads and brake discs for wear
Parking brake: Check free play of parking brake lever
Brake hoses and lines: Visual inspection for damage, routing and corrosion
Steering gear: Visual inspection of the dust boots for damage
Tie rod ends: Check play and dust boots
Axle joints: Check play; visual inspection of the dust boots for damage. Check the screw connections of the front and
rear running gear adjustment points are secure
Drive shafts: Visual inspection of the dust boots for leaks and damage
Exhaust system: Visual inspection for leaks and damage; check mounting and heat shields
Tires: Check condition and tire pressure
Check firewall and cabrio section body drains for debris
Check the door, lid locks and safety hook of the front lid for secure seating and function properly
Seat belts: Check function and condition
Vehicle lighting: Check function
All headlights: Check setting
Horn: Check function
Windshield wiper/washer system, headlight washer: Check fluid level and nozzle settings (use winter antifreeze
protection during winter months)
Check wiper blades
Battery: Check condition and electrolyte level
Electrical equipment, warning and indicator lights: Check function
Additional maintenance for spark plugs
Labor operation 03 81 00 ..
Replace spark plugs every 40,000 miles (60,000 km) or every 4 years
Additional maintenance for drive belt
Labor operation 03 60 00 ..
Check drive belt at 40,000 miles (60,000 km) or every 4 years
Check drive belt at 100,000 miles (150,000 km) or every 10 years
Check drive belt at 160,000 miles (240,000 km) or every 16 years
Additional maintenance for convertible top
Labor operation 03 70 00 ..
Maintain and care for convertible top at 20,000 miles (30,000 km) or every 2 years
Additional maintenance 60,000 miles (90,000 km) or every 6 years
Labor operation 03 83 00 ..
Replace drive belt
Change all-wheel drive controller oil – 911 Carrera 4 – 4-wheel drive models
PDK Change clutch oil
Additional maintenance every 120,000 miles (180,000 km) or 12 years
Labor operation 03 88 00 ..
Change manual transmission oil
Change PDK transmission oil
Change front differential oil – 911 Carrera 4 – 4-wheel drive models only
Every 2 years
Change brake fluid
Every 4 years
Replace tire sealant
After 4, then every 2 years
Check battery for the tire pressure monitoring system
After 4, 8, 10, then every 2 years
Inspect airbag system
Assembly and running gear mounts: Visual inspection of all rubber/hydraulic mounts for damage
Inspection Performed - Technician Signature: ____________________________________________
Road Test Check
Remote control, front seats, foot brake and parking brake (also operating travel), engine, clutch, steering, transmission,
ParkAssist, automatic speed control, PSM switch, PASM switch, Sport switch, heater, air-conditioning system and
instruments: Check operation
Oils, fluids: Visual inspection for leaks
See U n Rear View's Avatar
See U n Rear View is just really niceSee U n Rear View is just really niceSee U n Rear View is just really niceSee U n Rear View is just really niceSee U n Rear View is just really nice
Old 09-20-2012, 06:32 AM
Poshaman's Avatar
I got mine done around 42K miles and the dealer recommended plug change. I just followed their recommendations. My car was still under CPO warrenty at that time and I didn't want to take any chances.
Old 09-20-2012, 06:42 AM
Here is the check list for the 05-07 model years.
Old 09-20-2012, 07:49 AM
spyerx's Avatar
spyerx is a jewel in the roughspyerx is a jewel in the roughspyerx is a jewel in the rough
Just had oil change at dealer and asked about 4 year / 40k service. Its oil, filter, air filters, cabin filters, brake fluid, spark plugs, full check and inspection of car. I got an estimate of about 1200. Most of that is the plug change. This is at a SoCal dealer.
Old 09-20-2012, 08:02 AM
GTRR's Avatar
GTRR is just really niceGTRR is just really niceGTRR is just really niceGTRR is just really niceGTRR is just really nice
I got it done at Hegersheimer in Lake Forest....It ended up being about a $140 oil change! I got the air filter separately for $120. So, I guess $260 total wasn't bad! Go see Chris Sterling in Laguna at Grand Auto across the freeway from the Irvine Spectrum! Way cheaper. If your car needs major work, he'll hook you up with Vision Motorsport.
G
Thanks!
Old 09-20-2012, 08:10 AM
ECS Tuning - Porsche's Avatar
We offer a Major and Minor Maintenance Kits. The major maintenance is recommended at 36,000 miles, and every 36,000 miles thereafter (72,000/108,000/etc.) on your Porsche. This is in addition to your regular oil changes.
For more information on the kits we offer at ECS: Click Here
Old 09-20-2012, 09:38 AM
GTRR's Avatar
I love that DIY Kit! How much is that?
Old 09-20-2012, 10:23 AM
Thank you !! PM sent
Old 09-20-2012, 11:31 AM
sizquik's Avatar
sizquik has a reputation beyond reputesizquik has a reputation beyond reputesizquik has a reputation beyond reputesizquik has a reputation beyond reputesizquik has a reputation beyond reputesizquik has a reputation beyond reputesizquik has a reputation beyond reputesizquik has a reputation beyond reputesizquik has a reputation beyond reputesizquik has a reputation beyond reputesizquik has a reputation beyond repute
I just paid $790 before tax for a major service including new plugs. I was not charged for a new air filter as I run a BMC.
Old 09-20-2012, 01:45 PM
dartdash's Avatar
dartdash is on a distinguished road
which dealership in LA did you use, i was quoted $1800 at downtown LA Porsche.... thanks
Quick Reply: 40K Service
