Cayenne Turbo Battery Replacement Guide DIY
Old 11-29-2012, 12:08 PM
VIPNiSS's Avatar
VIPNiSS is on a distinguished road
This was done on my 2005 Cayenne Turbo. I only have a battery under my drivers seat. I think some might of came equipped with a battery in the trunk.
I did't want to pay the dealer $400+ for a OE battery and labor. I was able to get mine from Advance Auto Parts for about $130 after coupon code.. It took me about 30 mins max!
http://shop.advancea...8agm&showTitle=
NOW PUT IN THE NEW BATTERY AND DO EVERTYHING IN REVERSE ORDER!!
Remember to put blue loctite on the seat rail bolts and manual calls for 37ft lb torque.
Old 11-29-2012, 02:31 PM
ciaka's Avatar
...great write up...should help us all. Thanks for the post, I was going to look into how this would be done, but with the info, it will be easy.
Old 11-29-2012, 07:45 PM
rymo926's Avatar
rymo926 is on a distinguished road
Thanks for the write up
Old 11-29-2012, 07:58 PM
VIPNiSS's Avatar
Forgot to mention.. put blue loctite on the bolts for the seat rails and also the manual calls for 37ft lb torque
Old 11-29-2012, 09:36 PM
Cole's Avatar
Cole is just really niceCole is just really niceCole is just really niceCole is just really nice
Thumbs up
You spent more time making the write up than it takes to change the battery
.....now go write one for the other battery
Old 11-29-2012, 10:12 PM
VIPNiSS's Avatar
lol.. i would but dont have another battery
Old 11-29-2012, 11:27 PM
ciaka's Avatar
It often is the easy jobs that intimidate and scare those new to the car maintenance. Having these write ups helps to give others the info to complete as diy. Otherwise tbey are much more likely to pay to have it done. So good job and keep em coming.
Old 11-30-2012, 06:21 AM
Hal 2000's Avatar
Hal 2000 is just really niceHal 2000 is just really niceHal 2000 is just really niceHal 2000 is just really niceHal 2000 is just really nice
Thanks for all your time making this pictorial- Will be printing.
Old 11-30-2012, 08:06 AM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
Great post! I am somewhat used to turning a wrench and actually thought that accessing the battery under the seat was unnecessarily complicated.
My biggest frustrations was:
1) You need to move the seat a few times in order to get it completely out of the way. This thread makes it easier to understand.
2) I had to remove the plastic seat rail covers in the rear since they got "pinched" (and subsequently broken) when tilting the seat back. The owners manual did not mention this and I had to buy replacement seat rail covers.
Old 12-02-2012, 02:23 AM
loveivs's Avatar
loveivs is on a distinguished road
Good write up. Very useful post.
I had battery replaced in Sep. IF........bla bla bla
Old 12-05-2012, 04:54 PM
pcst's Avatar
pcst is a jewel in the roughpcst is a jewel in the roughpcst is a jewel in the roughpcst is a jewel in the rough
I've always wondered why in the hell they put the battery under the driver's seat.....
Old 12-05-2012, 05:23 PM
Moderator
I am sure having it so low is better for weight distribution and lower center of gravity. However, it is more complicated than I would prefer. At least you only have to access it once every 5 years, so I guess the minor inconvenience is worth the handling gains.
Old 12-05-2012, 06:42 PM
rbb1991's Avatar
rbb1991 will become famous soon enough
Great write up!
Old 12-05-2012, 06:48 PM
B3nz0's Avatar
B3nz0 is on a distinguished road
On a side note, does anyone know if an optima yellow top or kinetik racing battery will work/fit?
Old 12-06-2012, 02:57 AM
pcst's Avatar
I've been looking for this info as well, optima will last longer.
Quick Reply: Cayenne Turbo Battery Replacement Guide DIY
