When did engine bearing housing change?
Old 10-15-2013, 10:56 AM
sullivas's Avatar
sullivas is on a distinguished road
Anyone know when the engine bearing housing changed to the type where the case has to be separated to replace the IMS? I have a late 2005 M96 engine and the car's VIN is not included in the recall settlement, even though it is a 2005. So I am concerned that if something goes wrong with the bearing the engine will have to be disassembled to repair it,instead of just popping in a new one.
I did read in the archives that the bearing was changed in late 2005 models. But the case?
Also if it's the newer case I can't proactively replace ($$) with an L/N.
Thanks for any info!
Old 10-15-2013, 11:22 AM
jhbrennan's Avatar
I'd check with the guys at LN - here's some info from their site:
http://www.imsretrofit.com
Old 10-15-2013, 05:37 PM
italdream's Avatar
italdream is on a distinguished road
I am curious to know the answer. I heard a few times that they cannot determine it until they open the engine. It sounded odd.
Old 10-15-2013, 07:31 PM
mattyf's Avatar
mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !
There's a thread on rennlist where owners tried to discern the crossover point based on engine numbers. I suspect if you're not on the recall list you have the larger non-serviceable bearing, but really I don't think you can be sure until you look.
Old 10-16-2013, 03:12 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Failure rate on the later bearing has been less than 1% suggesting a very low probabilty it will fail if the engine is properly maintained. Keep in mind the guys making the most noise about failed IMS bearings are the guys who make their living replacing them.
04-28-2022 12:38 AM
00aston
08-27-2015 12:01 AM
Sales@RSW
BMW //M
08-26-2015 06:41 AM
ECS Tuning - VW
08-24-2015 01:51 PM
su_maverick
08-21-2015 07:14 PM
Quick Reply: When did engine bearing housing change?
